Hi Guys,
Just my two penn'orth: -
I bought a very similar one, similar shape, design and size (as far as I can tell), but no leather case - mine has a clear plastic hinged lid and a couple more buttons - from Maplins for either £10 or £20, can't remember.
I'll try to answer points raised by others:
1) effect of cartridge magnet - tried mine with fridge magnet and no attraction so cartridge magnet shouldn't have any effect.
2) height of scales - may be coincidence but mine is almost exactly the same height as the difference in height between top surface of LP on platter with mat in place, and the top of the upper surface of the deck, so placing it under the cartridge rest position and lowering the tonearm on to it gave the 'weight/force' at the correct height, give or take a gnat's cock. (technical term ).
And, most important, I'm happy with the resulting sound.
Cheers,
DaveK.
My System:
