Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
Thread: Stylus Tracking Force Gauge
    Alex_UK's Avatar
    Default Stylus Tracking Force Gauge
    I need to get both my turntables setup properly - don't have a gauge, they appear to be expensive - any reason why I couldn't use one of these? http://cgi.ebay.co.uk/Precise-Digita...d=p3286.c0.m14
    Or, any other suggestions (I vaguely rememeber Marco mentioning a digital food scale from a Pound shop - but this looks like it would be smaller and easier to use?)
    Alex
    Smile
    The magnets in your cartridge may well upset the instrument.
    Dave
    Why not, Alex... As long as it's non-magnetic, you should be fine
    What a bargain, eh, compared to an 'official hi-fi design'? It’s quite elegant looking, too.
    It always amazes me how products already sold in other markets gain a zero (or zeros) on the end of their price tags as soon as they are 'designed' (or should that be labelled) for the hi-fi market....
    Hi Dave,
    Would that not also apply to the ones from the Pound Shops? If so, it's not an issue with mine
    Smile
    You just can't tell!
    Dave
    Alex_UK's Avatar
    Cheers chaps, must we worth a go then, for the money - I can always bung it back on ebay if it doesn't work (and I can be bothered about a tenner...) I'll order one and report back.
    Alex
    I'm Hugo.
    I have the one sold by Origin Live, Roksan etc, and am happy with it.
    What I would like to know is the importance of the height of the measuring surface. The OL gauge is set to roughly LP height, but that cheap eBay one is clearly set much higher. Does it matter; and if so is it arm-dependent? Where do potential errors arise, if at all?
    As I already have a suitable gadget, it's of academic interest to me, but for someone wishing to buy one, a technical explanation would be useful, if anyone has the expertise to comment!
    No problems with my scales, stainless steel top plate.
    Stick some polystyrene foam (Erase Away from Wilkinsons) on the top plate with double sided tape, this hold the stylus and cleans it at the same time.
    Question
    Hi Alex
    How will you know if the magnets in your cartridge are affecting the reading?
    Regards
    Dave
    With 1/4 inch of foam the magnet adds 0.03grams.
