Results 1 to 2 of 2
Thread: Which spike?
    I'm Phil.
    Default Which spike?
    Looking to spike my AR turntable (it's "The Turntable" with the wooden plinth).
    Should I go for spikes? If so, what kind...wood, steel, copper?
    If not spikes, then what....rubber hemispheres, pads?
    Any manufacturers to avoid?
    Best methods of attaching either...screwed/bolted or stuck on?
    Worthwhile doing either without an additional isolation platform?
    Weirdest thing I've found so far is an anti-gravity isolation device, based on two plexi-glass platforms, held apart by magnets at each corner, with their similar (and, therefore, repelling) poles pointing at each other. Nine hundred of your Earth pounds for that.
    I'm inthescottishmafia.
    Hunter S Thompson
