Results 1 to 3 of 3
Thread: Armpod creation for Amari Oxywell Mozart A 12" arm / Linn and Black Widow armboard
    Default Armpod creation for Amari Oxywell Mozart A 12" arm / Linn and Black Widow armboard
    A tonearm pod of aluminium tube construction. Will have adjustable feet and ebony armboard.
    Fitted to be interchangeable for both an Amari Oxywell Mozart 12" and a Linn arm.
    Tube top and tailed, smoothed and polished
    Protective tape applied, tube is filled with cast lead. Centre hole for armbase and tonearm cable.
    These pods are very heavy, and stable as a standalone armbase.
    Next up will be resin cap / aluminium disc base and footwork.
    To be continued...
    Resin now cast
    Height / level adjustable feet - machined finish underneath, polished on top / visible face.
    The finished article. With holes to take the Oxywell arm and also Linn 3 hole arms with centre hole.
    I have an armboard special for a Black Widow arm to finish making and then it's off to the Mississippi USA with them both.
