And I'm nervously waiting for someone to come along and prove I'm talking rubbish. Again.
I'm Richard.
ABD.
Twas me
I will be using the arm on a Palmer 2.5 turntable which is currently fitted with an SME IV and a Koetsu Black Goldline.
I already have some experience with air bearing tone arms of the angle slider variety, having made one myself based on Ladergaards design. I had it mounted on a Garrard 401. I made the brass knife edge bearing parts myself on a CNC lathe.
I'm Richard.
I too started out with a pure Ladergaard which was tricky to level. I run my system in my cellar, the 1906 floor only has a thin skim of concrete which results in the deck moving fractionally due to temp and humidity. With the T3Pro the level adjustments are very quick and easy to achieve. To make it even easier I use a very accurate round bubble level on the manifold; when checking the specs of these things I found their accuracy/sensitivity can vary by a factor of 10.
I found humidity to be a factor in keeping my Ladergaard level on the 401. The DIY plinth was laminated birch ply, and the base of the Ladergaard arm Ash wood. The plinth and/or the arm base would move very slightly depending on (what I put it down to be) the humidity. I could find no other explanation for it periodically going out of level.
I'm hoping it's going to be easier on the Palmer with the easier level adjustment of the TP3, although the plinth is also laminated ply, so I may find a similar problem.
I'm Sam.
Ok... I know what you're saying.
Perhaps what I'm thinking about is not necessarily the cog and so how the suspension is balanced but where the masses (the cart at one end and the counterweight at the other) are positioned in relation to the springs and their axis of perfect bounce set-up. Again, not about actually tilting the suspension but about perfect bounce set-up on a suspended deck. But I guess you could say that about changing from 180gm vinyl to some wafer thin thing from the 80s.. and who really adjusts VTA for every record in reality? Probably going to cause more sound change than anything balance related.
Ignore me, just thinking out loud and not thinking about it for very long at a time either
