Are your tone controls flat especially the bass? Try everything possible inc headphones.
I'm Andr'e.
yes mate i use the amp on source direct.
My System
John Wood KT88 Amp.
Paradise Phono Stage
Sony TTS-8000 Turntable.
PMAT-1010 MK6 Tonearm.
Ortofon Cadenza Bronze
Sony X555ES Cd Player
Yamaha NS1000m Speakers
I'm Andr'e.
& is it the same with headphones?
that i dont know as i dont have any.
My System
John Wood KT88 Amp.
I'm Andr'e.
Have you got a blank side of a record you can just temp set the antiskate up 2/3rds the way in so it plays stationary try that
Those light tracking vms carts can be funny buggers imo Jamie. Did it give the same trouble with the at95?
ok heres what ive done that has greatly improved the distortion, ive turned the vtf weight up to 1.6g which is at the maximum weight range,i then used the hifi news test record on the last anti-skate track (the one they call the torture track) to get the distortion balanced in both speakers,its actually showing on the anti-skate setting slightly above 1g.also as a guide it sits ok to on the blank part of the disc as well.
it does kinda tell me that perhaps ive been setting the vtf on the low side before.
does what ive done make sense guys?
My System
John Wood KT88 Amp.
Yes. Disregard the quoted downforce. How do they know what turntable set-up the cartridge was destined for. Use whatever sounds/works best. A bit more won't hurt. I take it you're using the VMS30 Mk.II, so the diamond tip is I believe, the same as that on the MC25FL which can track at up to 2.5g without problems. Just keep an eye on the stylus cantilever suspension movement as the VMS30 Mk.II is more compliant.
My System
John Wood KT88 Amp.
