Cables going cheap !
Pure AV Speaker cable – a bit more than 3,5 metres long ; Z plugs (banana compatible) both ends. This was a bit of a hit on here a while ago. Good condition with a few marks. Postage will be quite a bit, as it’s heavy. £Sold.
Unbranded toslink cable – 8 metres. Used to connect a cheap DAB unit to the DAC. Its length was useful and caused no transmission problems. £15 including postage.
Unbranded RCA – RCA digital co-ax – 3 metres. No idea where this one came from ! £15 including postage.
NVA sound pipe with rca connectors. It measures about 40cm, but is very stiff as you can see in the photo. I used it between Tag Mclaren pre and power amps, and it gave a very clean, wide open sound. £Sold.
Unbranded RCA – RCA digital co-ax – 0,7 metres. £10 including postage.
Profi Gold RCA – RCA digital co-ax – 1 metre. Used between Tag DVD32R and AV32R. £15 including postage.
Pure AV Component video cable – 4,8 metres. A big, chunky rca cable that I used to connect the DVD player to the projector, then after that as a three channel audio interconnect for the rears and centre. Postage will be quite a bit, as it’s bulky. I’ve got two of these and a three-way inline connector that I’ll throw in if you want both ! £5 each plus postage.
how much would delivery be for the belkin speaker cable as i'm interested in buying it.
Belkin Speaker cable
It's very difficult to guess. I can find out on Wednesday for you.
Belkin
Postage is £5, so £15 all in.
1st refusal is yours if you wish !
Cordially,
Martin
I presume from the above it's sold but I'll have the speaker cable if not.
Sorry, Geoff, yes, it's gone.
Martin
- You may not post replies
- You may not edit your posts
Forum Rules
