Hi there
can anyone post a quick picture of what a genuine NAGAOKA cartridge warranty looks like, as would be found inside the box?
This would help me out in making a decision on buying a used cartridge....
Thanks
Robert
I'm bob.
Hi there
Thanks
Robert
all the used ones I have bought all come with a frequency response trace, signed and dated, Ask him for that.
I'm bob.
Problem with that is if he asked me what it was I would have to admit that I had no idea at all.
I mean is that something that would come with a new cartridge, or is it something that you get if you buy a used cart from a proper shop?
I really just need to know what the warranty card looks like. I mean EG is this a NAG warranty card? :
I would think it easier to fake a guarantee card than a cart. Could be a Japanese market one.
I'm bob.
That's an image pulled off a different place. The guy I am talking to says that inside the box there is no warranty card just the "paper owner's manual".
My problem is that I don't know what this "card" should look like. It is a Japan market one apparently. Low use. He is keen to sell, but I am being advised to be wary if no warranty card, which is why I need to know what it looks like... I mean does it have holograms, is it special at all... should it have a serial number on the card inside the box that MATCHES the number on the barcode on outside of the box?
......Or is it just a card where you fill in the number on the box and send it in....???
I really want to buy this but don't want to find myself stung in first cartridge purchase!
That looks like the instrution leaflet. I've not bought a new NAG since about 1995 but I don't recall getting a warranty card with it.
The frequency respone trace is a graph printed on a small sheet of paper, a bit like tracing paper, showing the response of the cart from 0Hz to 20K Hz and will be hand signed and dated by the Jap engineer who did the test. If he can show you that then it is more than likely genuine.
I'll check my Nagaoka cartridge paperwork tonight and let you know.
I bought it two to three years ago, but I don't remember there being a warranty card.
Kevin
I'm peter.
Are you suggesting someone is faking Nagokas? And if so, wouldn't they be sure to fake the papers too? I bought a Nagoka 500 last year and all it had was a small bit of folded paper.
With respect, you seem to be missing the point. Used cartridges are a potential minefield, you don't know how old it is, and you don't know if it has been mishandled. That's the bit to worry about....better, imo, to buy a fresh cartridge. It's too risky. Quite a lot of this stuff is close to knackered. I gave a Benz away, as part of a part ex with a dealer. It was worn out, next thing I knew it was being advertised as 'mint'. Have you noticed how nearly all second hand cartridges have 'low hours'? how does that work? Imagine cars with no milometer.
Then there's the oem retips claimed to be original........if you buy a used cartridge only, ever, buy from someone you know well and trust. And buying from a well-established member of the forum should be fine too.
As Peter says, you are worrying unnecessarily about a bit of paper when the cartridge might have been mistreated and worn out. It's always a risk buying a second hand cartridge unless you know the seller. Personally, I would never, ever buy a second hand cartridge.
