Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Chinese PSU voltage range
    I'm Brian.
    Default Chinese PSU voltage range
    As a few people have asked me this question I thought it best to start a new thread . I bought one of these http://www.ebay.co.uk/itm/25VA-24V-H...item19fb627f8b from Grant ( struth ) a couple of weeks ago and have been using it ever since with my Amptastic Mini-1 ( set at 13.5V ) . For some reason the seller doesn't point out in his Ebay listing that these PSUs can be adjusted. This morning I had a bit of a play and had the PSU adjusted down to 5V minimum and 24V maximum so these appear to be quite flexible . I've compared this PSU to the PSU supplied with the Mini-1 and it does make for an audible upgrade in SQ .
    The adjustment can be made via the little brass screw to the rear of the transformer . Sorry but I'm not an electronics engineer ( nor a photographer for that matter )so I don't know what these parts are called .
    I also found that changing the cable and the plug on the DC cable was a worthwhile exercise . http://www.ebay.co.uk/itm/OYAIDE-DC-...item2320762861 Not cheap but excellent qualiity .
    Tools required are a Philips screwdriver , an Allen key , and a little flat headed screwdriver . All available from the £1 shop .
    Regards
    Brian
    Amplifier : Sony TA FB740R
    Speakers : Tannoy 637
    Good one Brian. The part is a multi-turn pot (potentiometer).
    Alan
    what do you mean you dont know what its called Brian...its a thingie
    I'm Brian.
    Thanks Alan . I thought it was called a Dooverlackie ( adjustable ) or summat Grant
    Regards
    Brian
    I'm Alex.
    Thingameebob.
    I ordered one of these so it's good to know that the voltage is adjustable. Does it come up on the display or does the voltage need to be measured using a multi meter
    I'm Brian.
    It comes up on the display .
    Regards
    Brian
    Might be quite a handy box if the ampage was higher.
    OK, forgive the really stupid question. Could one of these be used to power a turntable? I'm thinking my 301 which needs ~17W.
    PRE
    MONO
    Pre Croft Epoch Power Sondex S100 Deck Garrard 301 Tonearm SME 3009 Cartridge SPU MONO mk II Phonostage Croft Music Maker Speaker Quad ESL 57 Cables Tonearm SME IC - Duelund Realsound Speaker SEAC 850C
    I'm Brian.
    Works very well with the Mini-1 Andrew .
    Regards
    Brian
