Page 2 of 21 FirstFirst 123412 ... LastLast
Results 11 to 20 of 207
Thread: Audiophile output on Mac OSX
    I'm Rob.
    Quote Originally Posted by sastusbulbas View Post
    Hello Rob,
    Have you ripped standard CD as WAV at 16bit 48khz and compared this with AIFF at 16bit 48khz?
    Steve
    No.
    Quote Originally Posted by aedagnino View Post
    Hi, I'm using a Beresford Dac with a MacBook, and when I open the Audio Midi Setup I don't have any options to tinker with in the audio output... am I doing something wrong? Is that an option for MB Pros?
    Something's wrong.
    Main system:
    Ben Duncan Mains Conditioner > Mac mini running Fidelia / Samsung 55 TV > Audioquest Crimson USB / QED Reference Optical Quartz > Leema Acoustics Elements DAC > Chord Clearway XLRs > AD Audio bespoke balanced valve buffer stage (oiw) > Chord Clearway XLRs > Bel Canto Ref500S > Chord Clearway speaker cable > Reiver Acoustics Edingdales > Audioquest SLiP Neutrik Speakon > BK Double Gem sub
    Hi Rob..
    Your post prompted me to sign on !!!
    Am just starting to play around with i-tunes library. I suspect like many others, also regretting not ripping my i-tunes libary to a much higher rate. vast majority at 128kbps with AAC. Last few weeks switched to Apple lossless...but am curious to play around, so will try AIFF.
    sadly ( well, not really as I could finally ditch our last pc in the house) I have inherited my sons old G4 Powerbook, which lacks optical out. Tried using an old Edirol UA5 via usb...but poor results, so am basically just using the headphone out for the time being.
    strange set up though...cable (mini jack to phono) runs from mac through the floor to a second hi-fi in recently refurbished basement, where a small system also doubles up as a home theatre.
    We have a spare Imac upstairs...but its not where the hi-fi lives.
    Anyway...thanks again for the set-up info.
    Steve
    I'm Rob.
    Glad the thread helps you out mate.
    Main system:
    cheers Rob..
    Now, getting a toslink onto this old machine is a bloody good idea...thanks. Might even make the Edirol DAC work OK.
    ...i have a cunning plan, almost.
    Whilst setting up the basement, before the plasterboard and plaster went up, I got a 25 meter run of network cable..no idea what to do with it, but had an idea that by plumbing it behind the hi-fi it might get used in the future. I demo'd the Linn DS, mightily impressed...but I'm not forking out that kind of dosh thanks.
    And they work on PC not Macs
    Next on the shopping list will be an ipod touch...and then able to utilise this
    http://www.alloysoft.com
    Even with the current Heath Robinson set up, I spent a pleasant half hour today listening to Goldfrapps new album playing from the hard Drive (just about to rip to AIFF as an experiment !)
    Steve
    Default Help!
    Quote Originally Posted by Filterlab View Post
    Depends on what OS you're running. These are the set-up procedures for Leopard, however the Core Audio settings haven't changed much from Tiger to Leopard.
    What digital output are you using?
    Hi, I'm using Leopard and I'm using the digital audio out (mini toslink) that comes with the MacBook (regular, white one, not the Pro). I've opened the Audio Midi utility and recognize everything you show in your pictures... except mine doesn't show any options for the audio out!
    Cheers,
    Alex
    One is a sinner. One is a saint, but most of us worry about showing up late. Pete Townshend - Street in The City
    I'm Rob.
    Alex, can you do a screen grab of your Audio MIDI Set-up for me and either post it on here of email it to me, I'll have a look and see if there's something not set-up quite right.
    Main system:
    I'm OneOfTheSevenModsWhoToldMarcoNotToLiftHarry'sBan.
    When you open Midi set up it probably looks like this
    click on properties for and choose built in output,then it changes to this
    Does this solve your problem?
    This is how it looks on my MacBook (non pro)
    ATB
    David
    Excellent tutorial BTW Rob.
    Been using this for a year or so now.
    ATB
    David
    Hi, thanks for everything... I finally found out how to change the options... I feel like a right t##t. Hehehe! I'll try the differences now... Ta!
    Hope it works for you Alex.
    Let us know.
    ATB
    David
