Page 1 of 5 123 ... LastLast
Results 1 to 10 of 62
Thread: unhappy with crap sound of my turntable
Hybrid View
Previous Post Previous Post   Next Post Next Post
    I'm james.
    Default unhappy with crap sound of my turntable
    Recently bought a turntable (ebay no 141521101827) spent considerable time setting it all up Ariston RD11s with SME3009/Ortofon M20E super MC cartridge.The preamp I was using is a Naim42.5 with MM phono boards it really didn't sound nice.
    I then bought another preamp meridian 506 from (ebay £148) fortunetely it had the correct meridian 506 MC phono boards inside it.
    It does sound better,but it still isn't good. If I could tweak my turntable to sound half as good as my CDs I would be delighted.
    The best way I can describe the sound is its boomy/basy and sounds bad/distorted if I turn it up loud.
    My power amps are meridian 205s speakers sonus fabor concertinos.
    Any help much appreciated as if this is as good as vinyl gets It is going on ebay to the higest bidder.
    Welcome James. nice to have another Scottish vinyl join. Your question should be put into the analogue section where it will receive better attention. The welcome area is where you introduce yourself, and tell us about your system, musical tastes etc.
    sure you will receive plenty good advice.
    Welcome to AOS James.
    We should be able to sort out your problems.
    Are you sure it's an MC. The M20E was MM if I'm correct.
    Is your phono stage MM and used with an SUT? An inadequate SUT can give results like those you describe with an MC.
    Also, what 3009 do you have, is it the detachable headshell type? If so you need a heavy and rigid cast headshell to work with MCs.
    I'm james.
    I think my cartridge is MM as the calibration card is printed variable magnetic shunt.
    141521101827 this is the ebay no of my RD11s price (negotiated outside ebay) for £350.
    My meridian 501 definetely has phono boards 515 definitely moving coil.another recent ebay purchase item no(171648077222)
    how lucky to find 2 515 boards inside it for £148 bargain.
    Not entirely sure what you're saying, but you definitely can't use phono boards intended for low output MCs with an M20 series Ortofon. The input will overload and distort.
    I'm james.
    Dont know what a SUT is
    Quote Originally Posted by surfwagon View Post
    Step Up Transformer. Bumps up the signal from low output MCs, so they can be used into an MM input.
    Think it is a moving Iron Geoff
    James, post a photo showing your arm and cartridge clearly. Maybe that will give us an idea. The Ariston is a good sounding turntable. You can get excellent results with it.
    I'm james.
    [IMG]M20Esuper[/IMG]
