I'm fairly sure most of them run on Android type systems. I doubt Windows gets much of a 'look in' here.
Think the binatone uses windows ce operating system
Can't say I've actually bothered to look at what my Binatones run on. They work, so that's all I'm bothered with really.
Sat Nav apps on mobile phones are definitely not free, with one exception. As you drive, they download the map data across the mobile network. This means that they need a 3g connection as well as a GPS signal in order to work. The amount of data they use is not inconsiderable, so if you are charged for data on your phone tariff it gets expensive, and if you're roaming it's frightening. However, it does mean that they're always up to date. The only exception to this is the NavFree app, which downloads the whole mapset for your country when you install it. Works a treat but make sure you install it on a wifi connection as it's half a gig of data. The ad free app is £1.99, with an extra £1.99 for each additional country IIRC. https://play.google.com/store/apps/d...M.ALL&hl=en_GB
None of this will interest you, Gordon! About eight years ago I bought a Tomtom Go 710. It's a doddle to use, it's never gone wrong and it works a treat. The only problem is that the maps are a bit out of date now and an update is about £40 or so, but it's not much of a problem. They seem to go for £30 - £50 on Ebay.
Time flies like an arrow.
Fruit flies like a banana.
Hi Gordon,
Get yourself a new touch-screen head unit/music system for the car, as most decent ones these days have sat-nav built in - and good ones at that. Keeps it all neat and tidy, and upgrades your sounds, on the go, at the same time. Job done!
Whatever you do, don't get the Bonnie Tyler satnav. All it does is tell you to "turn around" and then every now and then it falls apart.
