Originally Posted by
Werner Berghofer
Yes, this will work, but I fear you’ll find this a little bit troublesome. After converting the ALACs to AAC you’ll find duplicate track entries, which makes it necessary to use the ”Get Info“ menu item so that you can identify which track entry points to the ALAC and which points to the AAC file.
If you plan to use this method a ”Smart Playlist“ could help you a lot. Create a smart playlist containing only tracks with a sample rate below 320 or 256 kbits (or whatever sampling rate you use for mobile listening) and synch just this playlist to the iPod.
All that's true, but the doug's script is the tidiest way to get your music files from ALAC to AAC without keeping duplicates. It's just a slow process, that's the drawback.
Intel NUC/Chevron Audio NDF16 dac/Amptastic Mini-1/Audium Comp 5
Mains Block: Custom-HiFi-Cables PowerBlack Distribution Block (with super conditioner).
Connected with Reference Fidelity Components Super Neptunes and Speaker Cables.
Powered by Custom-HiFi-Cables DC2 psus
