Can anyone throw some opinions on this one. André has recently made me feel I need a kick up the butt and get a TT up and running. I had 2 non-runners recently, now I have one and two tonearms, but still nothing working, despite buying a fair few LPs over the last 6 months or so
So my question is, which of the two would folk recommend? I have read good things about both, especially the Carbon. It will be going into a Michell TecnoArm and I'll be using the MM input on my Rega Brio-R into Harbeth SHL5's. I'm not looking for razor detail, or thumping bass - I want a listenable, non fatiguing, musical cartridge that is easy to set up and that enables easy replacement of the styli. I play mostly Americana, lots of acoustic stripped back music, with female vocals featuring heavily, so mid-range is where I'm at I guess. I also don't go loud.
What would you pick or is there something else out there and I want to stay below £100 if possible and it must be MM? The only real experience I can draw on is from the 70'/80's when I had I think an AT95E and liked it, I had some kind of Ortofon as well, but cannot recall which one?
Thanks.
