Can't put this in Past masters 'cos "masters' doesn't apply.
However, its an interesting thing to have in the collection even if its not really hi-fi. The cover for the arm gubbins made me laugh. Basically, it's thin card stuck on with double sided tape
I've had it playing and it works but for the arm lift. Holding the arm up and then letting it drop on the record works OK. The sound is alright even if it doesn't exactly scale the heights. Aker sounded quite reasonable.
When I took it apart, the little white widget fell out. The sliders were all stuck as the grease had hardened. Quick WD to see if it worked, can grease properly later.
The bar on the top obviously adjusts the start and finish points but also obscures the end of the arm lift relay - which clicks in and out quite happily when instructed.
So, does anyone have any experience of these? Can I just undo the adjustment screw and lift off the bar? VE have a Users manual but not a service one. Its an JVC L-E22 by the way.
