Anyone recommend a good one that is easy to use and doesn't cost a fortune.
That's a bit tricky. The hand held ones will magnify enough, but they shake a bit too much due to hand movement for you to see the diamond very well. The USB microscopes tend to be too low a resolution for a clear image. Best result I've had is with a proper microscope fitted with a digital USB attachment.
Hi Rob,
Audio Origami is your friend. Pop Johnny an email (from his website) and tell him you’re looking for a magnifier - they may even be featured on his website, and certainly don’t cost much. I’ve got one and it works a treat!
Reading glasses work wonders
I'm mark.
Cheap x40 magnifier fixed to helping hand, photographed with iPhone
Can't make out the stylus type, but good enough to check for damage/cleanliness?
IMG_1702 by levs the diver, on Flickr
Precisely...
Here you go, the AO ‘spyglass’: http://www.audioorigami.co.uk/for-sale/
£8 - job done!
Hi, Thanks guys. I'm after something for general cart set up ie checking stylus \ cart is parallel with record from front, azimuth etc rather than necessarily for checking stylus condition. I guess the Spyglass should be ok for those things too - cheers.
While we're on it, I thought this was too cheap not to have
http://www.amazon.co.uk/HELPING-HAND...gnifying+glass
Mike
Good shout, Mike. I’ve got one (picked it up in Aldi), and they’re excellent!
used to have one as well and are handy little things. dunno where mine is now
