Originally Posted by
nuff
Thanks Derek! That's worked perfectly.
1 question. What position do you put your Bass & treble. It seems I can use both on the AV amp and stereo amp.
Thanks again mate, I'm well pleased.
No probs Nathan
My Teddy Pardo stereo amp doesn't have tone controls, so I just let the Marantz apply EQ settings based on what Audyssey auto setup suggests. If your stereo amp has tone controls, I'd reset them to zero when being used with the AVR and put them back to your preferred settings when listening to plain stereo.
Analogue
Technics 1210GR (AT-VM95ML)>Rega Aria mk2>Teddy Pardo i80a>Tannoy Eaton Legacy
Digital Stereo
Bluesound Node 2i>Chord Qutest>Teddy Pardo i80a>Tannoy Eaton Legacy
Digital Surround
(f): OPPO 103D>Marantz NR1510>Teddy Pardo i80a>Tannoy Eaton Legacy
(r): OPPO 103D>Marantz NR1510>Kralk Audio BC-30
(c): no centre
(s): no sub
Other
Headphones :Sennheiser HD650
Equipment Stands: Mana Acoustics
