Krell's ubiquitous muscle house the 300FPB (full power balance) highly desirable power amplifier. In good condition drives pretty much any speaker you care to mention with aplomb . No box / crate with this beast, so pick up only demonstration no problem. New cost £9500
Asking £2395
Specifications
Krell FPB 300 Power Amplifier Specifications:
* OUTPUT POWER
… 8 Ohms 300 W
… 4 Ohms 600 W
… 2 Ohms 1200 W
* FREQUENCY RESPONSE: 20 Hz to 20 kHz +0 dB, -0.05 dB
* SIGNAL TO NOISE RATIO: 113 dB A Weighted
* TOTAL HARMONIC DISTORTION:
… 1kHz < 0.03%
… 20 kHz < 0.16%
*INPUT IMPEDANCE: 100 kOhms
* INPUT SENSITIVITY 2.34 Vms
* INPUTS:
… 1 pair balanced via XLR connectors
… 1 pair CAST via 4-pin bayonet connectors
* OUTPUTS: 4 pair Speaker Binding Posts (upper left, lower left, upper right lower right)
* DIMENSIONS
… Width 19.0”
… Height 10.3”
… Depth 17.0”
Weight 90lbs
Review 1
http://www.coherent-systems.co.uk/contact.asp
