In the absense of a Linn setup jig (the 160 fits, as well as a Rega), use four coffee jars or large tins to space the underside of the deck enough for you to get underneath. make sure the deck is unplugged from the mains when twiddling, as the mains/motor wiring isn't shielded and when you pull your arm back, you'll have the deck on the floor in pieces (seen it done with an LP12 and nearly did this myself...).
