Aye, that's another thing, what's with the Yatra and Fuji models?
Hunter S Thompson
Hunter S Thompson
yep I know that situation well, for a much cheaper option why not send your maroon to John Wright http://www.london-cartridges.co.uk/ his rebuild prices are real value and he will return it like new
cheers
Paul
Truth is always new, totally unknown, and unknowable. The mind must come to it without any demand, without any knowledge,without any wish; it must be empty, completely naked. Then only truth may happen. But you cannot invite it.
JK Hamburg 1956,Talk 4
Hunter S Thompson
Hunter S Thompson
There's a bit on the Fuji here too: http://www.referencefidelitycomponen...zyx-r100-fuji/
Basically, the Fuji is the the top of the line R100 model, with refined wiring design, Boron cantilever and fine line contact stylus.
As Geoff says, ZYX cartridges are unusual in that there's not really a defined pecking order as such, because the designs are all slightly different. What they all share is a top notch generator design, very fine wiring and top drawer stylii. Of course the top end price-wose models are quite extraordinary (The Airy 3 remains my all time favourite MC hifi cartridge) but even the R50 will allow buy-in to their extraordinary musical and satisfying sound.
I also agree with Geoff that the R50 is an outstanding bargain in high end cartridge terms (it performs as well as many at four times the cost) and it has a lovely airy soundstage with a full bodies presentation and solid bass. It isn't analytical like some.
I echo pretty much everything Geoff says.
I have a Decca Blue/Deccapod and a Zyx R100 H. The Blue is pretty much the same as the maroon but has a spherical rather than an eliptical stylus. That said it is the best tracking cartridge I have ever owned - tracks all 4 test bands on the HfN disc with ease. The Deccapod IMO is a must and refines the presentation significantly. Both carts need mass in/on the headshell to work properly (the Deccapod) adds this. I found the Zyx needs an additional weight unless you have the type that comes with a metal base plate. I found the 3g VPI from Analogue Seduction (http://www.analogueseduction.net/hea...ll-weight.html) in a Oyaide HS TF headshell works just fine. The Schick graphite http://calamightysound.blogspot.co.u...dshell-is.html is a great partner for the Decca. IMO both these carts need to be considered with the headshell they are going to be mounted in. Of curse with the Zyx you also need to carefully consider what SUT you are going to use if your amp doesn't have a MC input. With the Decca careful attention to earth/ground is vital to minimise hum.
The Decca is supremely fast and detailed - I could happily live with it if it was the only cart I ever owned. Unlike Geoff I am not minded to move mine on.
The Zyx to my ears has many of the same qualities as the Decca but has a fuller more "musical" presentation. TBH at times I have found myself asking is the Zyx adding colouration where the Decca is just telling it like it is? Not sure really. Overall, I do prefer the sound from the Zyx on the majority of recordings I have.
Steve
Always a little further
Just a note for anybody considering a ZYX.
I'd suggest the 'H' version of each cartridge. The H stands for high output, but that is in relation to the lower output variants of each cartridge model. The H is still a low output MC and will probably be the best option to match to regular MC inputs, phono stages and SUTs.
The low output versions are I believe, supposed to have an edge soundwise, but I doubt there'd be much in it.
