Having just bought a rega r200 I need a second headshell. I believe it is the standard sme fitting. Before I buy something new I thought id try here. Will be to use with either a denon dl304 or an ortofon 2m black.
If you want a cheap solution try one of these:
http://www.ebay.co.uk/itm/SILVER-HIG...item4ada5f4efa
They are rigid and surprisingly well made. I have a couple.
Or this perhaps ?
http://www.ebay.co.uk/itm/Malvern-Au...item43c42f60df
