Be good to collect local to Glasgow than pay silly postage fees!
thanks.
thanks.
Your local pharmacy.
Me so horny- Impulse H6 Horny
I'm ChrisB.
Do you know anyone who uses a dehumidifier?
They chuck the stuff away.
Just visit any hardware shop and buy deionised water used in steam irons.
Deionized is different though?
Wee bit of research, found this place, free delivery.
2 x 5L bottles for £9. £22-30 elsewhere.
Sorted.
http://www.barberdts.co.uk/distilled-water.html
Halfords.
Hunter S Thompson
I'm alan.
I use the water butt in the garden.Steam irons and m/c ,car batteries ,not given any bother for the last 40 years.
Batteries don't last long enough to make a difference,IMO..
Revox B795,NVA Phono 1,Teac PD H500C,SB Touch,Mark Grant Linear PSU,Bushmaster MkII,NVA AP70,IPL LS3TLM.Royd Minstrels.
I'm Gone.
When I mix "The Right One" vinyl cleaner I use six way purified, the process uses reverse osmosis, steam distillation and de-ionisation with an audited less that 1ppm residual impurities. Most batches come certified as zero ppm. I also use medical grade chemistry, this is the only way to get the records pristine and keep them that way. I wouldn't use anything less on my own records either.
I'm Jay.
