Help needed please. I intend to use my Mira as a pre amp. Can you switch off the power amp section and adjust the pre amp gain internally on the Mira 2000 in the way you can on the Mira 3? If so do I remove only the back panel to access it or is there more casework removal necessary? Any advice on the gain settings? Thanks in advance.
