Yesterday I was over at Macca's gaff where we had ourselves a mini passive pre bake-off.
Both of us seem to be attracted to the concept of how LDRs work and certainly on paper from an objectivist perspective they should sound very transparent and uncoloured. We had both bought a cheap Stereo Coffee single input LDR pre kit (~£50) about 8 months ago! and it was high time to try them out and see if Objectivist theory and Subjectivist reality would converge...
I made mine into a 2cm thick limestone box:
Meanwhile I'd also bought a Tortuga LDR3x.V2 kit (~£250) with dual LCD displays and manual and remote control.
Not made the case for this yet, so here it is languishing naked next to the 12v power supply I made for it:
Macca has an NVA P90SA pre (£640) which uses these Shinkoh/Elms 24 stepped attenuators and I can imagine it's as good a stepped attenuator passive as any out there and probably better than many. (I also used to have one of these for a couple of years before I moved it on and liked it).
We used the excellent Red Hot Chillies album 'Blood, Sugar, Sex, Magic' as music fodder and tried to level match as best as we could with the sound meter on my phone (not perfect but close enough).
It was clear pretty quickly that both LDRs were very close to each other and a step up on the stepped attenuator. The stepped attenuator was more fuzzy, less detailed, less transparent than both LDRs. The LDRs had better slam on the bass and more of a sparkle at the top end with cymbals and high-hats etc. We both remarked on the excellent reverb and decay.
In the end the LDRs were addictive to listen to and we didn't want to turn them off, in a way that the Stepped Attenuator wasn't.
While the 2 LDRs were very similar we both thought that maybe the Tortuga just had the edge by a whisker. The other thing about the Tortuga is the awesome engineering and attention to detail that's gone into it as a product. It's clearly a labour of love by a genuine hifi geek and it's the kind of thing I'd love to be doing if I had the skills.
The stand out features are that it has built in and automatic channel matching controlled by the embedded software. The Apple Remote control option and the dual LCD displays are icing on the cake. I also understand that in the near future it will be software update-able via it's built in USB interface and there will also be an android/iphone app to control it.
On the other hand, the Stereo Coffee LDR is wonderfully affordable at only £100 for 3 inputs and considering it sounds 95%-99% as good as the Tortuga it's also a very compelling proposition.
I needed 2 pres so I didn't have to choose between them, but if I had to rank them on their overall package of sound and features it would be thus:
1. Tortuga LDR3x.V2 (~£250 for 3 inputs and with all the options: manual and remote control, dual LCD displays)
2. Stereo Coffee LDR (£85 for 3 input version)
3. NVA PS90SA (£640 with 6 inputs)
To make sure these comments are put in the right perspective, all 3 pres were excellent and it wasn't night and day between any of them. The comments are relative to 3 very good passive pre amps.
I'm looking forward to some long term listening with the 2 LDRs and will post more comments, but I'm now wondering if LDRs have matured to the point that make them the ultimate passive pre?
