Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: I'm a lucky boy - new C-J ET3 preamplifier.
    I'm Alex.
    As far as I know, a phase inverting preamp is designed that way as it permits one less stage in the signal path, theoretically improving sound quality through a simpler circuit. Most CJ preamp seem to be phase inverting - not sure if this is a 'tube' thing or whether it is common with solid state preamp also.
    The user manual suggests reversing polarity of the speaker cables with a phase - correct power amp, and suggests that there is a significant SQ benefit. Mine is, so I follow their advice, although I haven't experimented extensively to see if this is so.
    I like the Gold Lion 6922 very much, not least because it is a very quiet tube. I am also about to try some cryo treated Voshkod 'Rocket' 6N23P - hope they are good... have a very good rep and are cheap. I got them from Watford Valves, and have always had a good experience with what they supply.. tested for noise, microphonics and have closely matched triode sections. If they work well, I'm going to buy a few more to set aside while they are still available!.
    Cheers,
    Alex
    Technics SL1210| Jelco SA-750| Benz Micro ACE SM MC| Squeezebox Touch/MCRU linear PSU | Cambridge Audio 851C | High Resolution Music Streamer II+ / Linestreamer+ | Raspberry Pi 2/IQ-Audio DAC+ / Max2Play | Conrad-Johnson ET3 Control Amplifier| Conrad-Johnson LP125sa KT120 Power Amplifier| Avalon NP Evo 2.0 Speakers| Cardas Audio Quadlink-5C Speaker Cables and Interconnects| Finite Elemente Pagode Signature E-14 equipment support
    I'm Alex.
    P.s. I am using Ei 12AX7s in the phono stage, and I have to say that they are also pretty awesome. Apparently you will have a hard time getting low noise/low microphonics Ei 12AX7, but if you do they are some of the best sounding around, with some comparing them to top notch Telefunkens. I don't know about that but they seem to have great detail, a defined but smooth treble and good balance from top to bottom. Might be worth finding a seller who screens and selects them as they aren't pricey.
    Cheers,
    Alex
    I'm Phil.
    thanks for that , very helpful
    Eric Bibb
