I love mine.
a few things to check:
- make sure the tonearm cable is clipped to the plinth to avoid any foul play with the suspension
- make sure the belt is siting nicely on the belly of the pully to avoid any drag. That is done by a clever combination of tightening and loosening bolts around the motor.
- don't over do the suspension as the plastic grommet are hard to find nowadays
- when you have time, think about fitting an Armageddon clone PSU to it!
Mine is fitted with a Jelco 750D and a Goldring 2200 MM, and it is wonderful!
Enjoy
Francois, Bergerac, France
Source component/s:
Musical Fidelity M1 Dac, Allo Digi One, Sony SCD-XE800, AVID Ingenium Twin arm, Audio Note Arm One, Groovemaster II 12in, Audio Note IQ3 MM, Denon DL103R MC, Croft Basic 25, TQ Iridium Phonostage, Puresound T10 Stepup Transformer, Zavfino majestic tonearm cable
Amplification:
Audio Note OTO PP, Dussun V6i
Loudspeakers:
Triangle Comete ES, Klispch RP600M
Cables/stands:
Quadraspire, Belden 9497
