Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 57
Thread: Slic Innovations Eclipse C Interconnect at MCRU
    I'm Neil.
    What DAC do you use Choirboy?
    I'm Nat-andthat'swhyIdrink.
    Quote Originally Posted by choirboy View Post
    Well I've take the plunge and ordered a couple of pairs
    Shame there's no thread to tell us what you think! I'd be interested to hear. Perhaps you should start your own page in the gallery forum (if you haven't already) then it is quite clear that it's your own opinion and not open for discussion..
    P.S. Are the cables shielded at all or just the two concentricly, counter-spiraled conductor paths?
    I'm Michael.
    I don't have a DAC. They will be used between Pre and Power Amps and CD to Pre Amp.
    Vinyl: Pro-Ject Xpression MkII + Speedbox MKII + Goldring 1042MM
    CD: Cambridge Audio 851C
    Network: Bluesound Node 2
    Amps: Musical Fidelity A5CR Pre / Power (JS Audio full upgrade)
    Speakers: Harbeth Monitor 30.1
    Cabling: Tellurium Q Black Diamond / Studio Connections Black Star / Graditech Kide Digital
    Mains: James Audio MK7 Power Conditioner, Studio Connections Black Star, Synergistic Research Orange fuses
    Support: Creaktiv Rack, Hi-Fi Racks 30.1, Black Ravioli
    I'm Michael.
    Quote Originally Posted by nat8808 View Post
    Yeah I know. It's annoying when bickering takes over a thread and forces it to close. Yeah, I'll add my thoughts to my gallery page.
    Strokes of genius is where you should post if you like the cables
    Only if it's a full-blown review, otherwise all cable discussion should go into The Artist's Palette.
    However, that said, there's nothing wrong with Michael adding a few thoughts about the Slics on his Gallery thread.
    Who is that question aimed at young man?
    I appreciate the young man bit! Thanks. I guess you if you know.. do you know?
    I'm not sure if shielding is always a benefit or not but has been on my mind recently regarding Oyaide cables etc .. just got some old Deltec Black Slink ICs with the shield as a seperate earth, wasn't sure if I heard a bit more of a freshness to the sound or if it was a one-way observation via auditory memory from the night before, will have to try again.
    The SLIC is shielded, personally I have done listening tests with and without and a couple of my testers have and it works, well the type of shielding I use does.
    I also sent out 2 identical cables with oyaide 510 cable both had the same plugs on, one was with shielding one without
    The shielded one sounded marginally better.
