I'm steve.
collector and DIY user of old british triode valves
Open baffles / single ended diy px4 and px25 valve amps
I'm Nat-andthat'swhyIdrink.
They originally came with a removable padding which fitted behind the electostatic panel - perhaps this was supposed to solve that problem but normally was lost?
Sounds like it to me. Probably disintegrated like the foam on 3090 tweeters did. I can't see anyone releasing a speaker that sounds as bad as that. I also don't see Sony buying into it if it sounded that bad and then you have the majority of reviews saying they sounded great.
They are/were heavy duty cloth things filled with something and almost quilted in construction (I guess to lend themselves to a curve) - a bit like some kind of draft excluder fire protection.
