What is the point of clamps?
I recommend the KAB Super Record Grip - see http://www.kabusa.com/usagrip.htm . It's relatively inexpensive at $40, lightweight and I like what it does on my TD-124 and Kenwood DD decks; however I don't have a Technics.
Hi Mike,
Yes on the latter - not had a chance to reply to it yet, but will do later today
Yes, I've used both the Bruil and Michell clamp, and whilst I liked the latter, I felt that the Bruil produced the better results. The Michell clamp, I feel, (unsurprisingly) produces its best results on Michell T/Ts, where the whole design system works 'as one'.
I've also tried other clamps with the Technics and results have been less than inspiring. My view is that record weights are likely to be more effective on the Technics, but not ones too high in mass. The Bruil weight does pretty much everything that it says on the tin, and isn't stupidly priced:
http://www.soundfountain.com/amb/puck.html
Interesting explanation here, from Michell, on the design principles of their clamp (and platter):
http://www.michell-engineering.co.uk...ter-and-clamp/
Note in particular:
Observe the highlighted parts in blue... It is obvious that the clamp and platter have been designed to work in tandem with each other, in an effort to remove resonances from the playing surface. However, the coupling effect is only of benefit if the material you're coupling it to (what the platter is made from, and also the mat) is a good impedance match with the vinyl record itself.Originally Posted by Michell-engineering UK
Therefore, using a Michell clamp (or any clamp) on a T/T whose platter and/or mat haven't been optimsed for that effect is more likely to produce negative results, as effectively all you're doing is coupling the record to a sub-optimal interface, thus superimposing its adverse sonic signature onto the music signal.
What we are trying to achieve, by using a record clamp or weight is precisely what is outlined on the website, where the Bruil weight is discussed:
In my experience, most turntables benefit from the use of some sort of weight or clamp, and those benefits are obtained when the above goal has been successfully achieved.Originally Posted by Soundfountain.com
However, in terms of the Technics SL-1200/1210, experience also suggests that the above goal is met more successfully with the use of a record weight than a clamp, and therefore, sonically, the results with the former are generally more positive. As ever, though, nothing is written in stone, so the key is to experiment and see what works best with your T/T!
Anyone any experience with the Harmonix TU-812M? A mere £2,494.99.
http://www.analogueseduction.net/rec...s/HTU812M.html
Yes I bought one and thought it was crap, I then upgraded to one which cost £5000 and got a deeper separation of instruments, black backgrounds, etc... A very worthwhile purchase.
anyway the clearaudio cleverclamp is quite possibly the no brainer of the century for keeping the record tight against the platter or mat?
