Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 47
Thread: System update
    I'm Ben.
    Very classy looking system you have there Barry.
    Technics SL1210 with
    SME IV Arm & AT OC9XML,
    Firebottle modded Tron Convergence Phono Stage,
    Bluesound Node 2i, Technics SL DZ 1200 CD
    Denon PMA1700ne amp
    Yamaha NS1000M Speakers.
    I'm Barry.
    Cheers Ben
    I'm Alistair.
    Hi Barry,
    That really is a beautiful system you've got there.
    Cheers,
    Alistair
    I'm Barry.
    Thanks Alistair
    I'm Andy.
    The Rega looks very pretty in your neat and well put together system Barry.
    Me so horny- Impulse H6 Horny
    I'm Barry.
    Thanks Andy, I must admit I like things to look right
    I'm Barry.
    A couple of changes in the last few months , I replaced the NADC370 integrated with a C162 pre , this unbeknown to me at the time would see my beloved modded Rega/2M Black shown the door. Having noted that the Pre's phono stage MM was pretty good not as good as the P10 mind you ,I then read in an old USA mag that the MC side was a revalation for an in built. Having tucked this info away , I thought I'd look out for another T/T to try an MC cart with the NAD pre. Along came the Systemdek , a few tweaks and an audition with a other MC stage and yep
    A new AT33EV cartridge and I haven't stopped playing records .
    Also got a Toshiba SD9500E , flagship DVD player , beautiful machine for use with the DVD-A discs I've been buying , that I'll listen to if I don't switch the Systemdek on first
    That Systemdek looks mint for a used buy. Very tidy system you have there.
    That rig looks cracking Barry; seems to be an excellent result all round
    I'm Graeme.
    Yes I see it has the Acrylic Platter option fitted - that's a good set up. If you are looking for a fairly cheap upgrade, the next time you replace the belt have a look at the Origin Live upgrade belt - I fitted on to my Systemdek, and it's a noticable improvement. (their bearing oil works well on the Systemdek too!) Just be careful to measure your existing belt when ordering, I found that their data on Systemdek belts did not match my deck.
