Results 41 to 48 of 48
Thread: L&R Channels flipped
  1. #41
    I'm Brian.
    Hope Gary can help Dave . I've been using the server which he built for me for 18 months now without a hitch http://theartofsound.net/forum/showt...t=music+server
    I've upgraded JRiver a couple of times and made a couple of changes to my system but the server remains . It's very reliable and sounds fantastic to me .
  2. #42
    I'm Gone.
    I use the optical out via a good quality glass toslink cable and it sounds really good using iTunes with Tune Up.... Still prefer analogue though
  3. #43
    Hi Dave, which player software are you using?
    Sorry in advance if you've already mentioned it, it's been a busy couple of weeks!
    Tom
    AKG K701, TC-7520 HPA/DAC, Yamaha RX-V396RDS, Some awful speakers
  4. #44
    synsei Guest
    I use Foobar2000 to play my music files but I listen to music on Spotify mostly therefore any solution involving Foobar will only solve the problem for that player
  5. #45
    I'm John.
    Are you using ASIO4all?
    If yes, have you correctly assigned the output channels?
    You need to do this for both foobar and ASIO4all.
    You can check in foobar/preferences/output.
    Single spur balanced Mains. Self built music server with 3 seperate linear PSU, Intel i5, 16 GB RAM no hard drive (various Linux OS). Benchmark Dac2 HGC, single ended XLR interconnects/Belkin cable. Exposure 21RC Pre, Super 18 Power (recap & modified). Modded World Audio HD83 HP amp. Hand built Monitors with external crossovers , Volt 250 bass & ABR, Scanspeak 13M8621 Mid & Scanspeak D2905/9300 Hi. HD595 & Beyer 880 (600 ohm) cans.
    The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts.
    -Bertrand Russel
    John.
  6. #46
    synsei Guest
    Quote Originally Posted by Welder View Post
    I am a numpty, I am using Wasapi not A4A...
  7. #47
    I'm John.
    Out of interest if you connect your computer to your dac via usb are the channels also reversed?
  8. #48
    synsei Guest
    Quote Originally Posted by kenworthy100 View Post
    Out of interest if you connect you computer to your dac via usb are the channels also reversed?
    No I haven't actually John, good call. Can't do it tonight as I am busy but will give it a go tomorrow morning
