Hi All
Well I have finally done my last shift at SSI.
Was a shame to leave but the pull of my new job (See post in Abstract Chat) was too great.
Thought I would post a couple of photo's that may be of interest (or not)
The first is me on the Cast House Floor after working on the Tap Hole Drill, that actually worked ok after I had been working on it, I am watching it at a distance (just in case it went wrong again)
The second photo is of an identical drive Motor and Gear Box that drives a belt that carries Coke (not the fizzy drink) to a stockhouse. The motor is a 3.3kV drive motor and a fluid coupling to the Gear Box.
The last photo is what we came across while checking out a failure to start fault.
The gear box is not seized, so what went wrong ?? You can see the motor has ripped off it's feet mountings from the main motor carcass. The hole in the fluid coupling casework should not be there either.
Andy - SDDW
Andy
