Bet the word 'audiophile' grabbed your attention! - well maybe the file based audio crew anyway
Gigabyte GA-H81N
This looks interesting and a step in the right direction as far as I'm concerned . . . dedicated boards with audio in mind. During my years of testing I did discover that some motherboards can influence the quality of the end product believe it or not, especially the cheaper ASROCK and MSI ones. Anyway these new Intel H81 chipset boards have stripped back feature sets with audio rather than gaming in mind, one board allows you to change op-amps but the feature that has caught my attention is a gold plated, isolated USB port which claims to supply clean, stable power to the port, which is separate to other USB ports. Additionally, you can isolate the 5V power from this dedicated 'audio' USB port, by turning it off in the BIOS, so all you get is the data stream, no power. In theory then all you need is a simple power injector like the Item Audio one, get yourself a small 5V linear PSU and voilą, a clean regulated and isolated 5V power line to your USB DAC and no need for an expensive iFi USB power brick or similar (in theory?). You could buy a motherboard, 1150 Haswell CPU, 5V linear PSU, RAM and power injector all for less than the price of the iFi-Audio iUSBPower
Going to buy myself this one, with one of the new 'T' rated low power i3 Intel Haswell CPU's and build another server, hopefully the last for awhile. I have found my 32bit Atom board (DM2800T) lacking on some fronts, so want a new build. It may well all be marketing BS, but we shall see? Certainly being able to isolate the 5V line on the board and having a dedicated audio USB port is going to be a good thing if you use a USB DAC, which I do.
This is the op-amp board;
GA-H81.Amp-UP
And the full range of new H81 boards.
Bring it on ASUS, what are you going to do to match this?
