I'm mike.
There's nothing wrong with the 610 and Dovedale combination, they give a good sound. The 610 has a decent phono stage, it was designed at a time when vinyl was taken very seriously and you'd spend a fair bit of money getting a valve stage that betters it.
I'm Gone.
Hi Mike
With the proviso that you revalve the it with some quality valves and use decent cables, I would give the X-10D a go. The Rotel has a nice phono input and the speakers are cool, so you'd have to spend a lot to get a better sound with an external valve phonostage
Cheers
Paul
I'm mike.
thanks for all the input. i havent heard any valve amps so i really have nothing to compare it with, its just i've read a lot of comments and reviews and nearly all favour the valve amp sound over SS, im basically trying to get a taste of valve amps over SS, to see if its for me, but dont want to spend too much. thanks again, mike.
Shame you're not nearer, would have been happy to demo the X-10D on your system. Maybe there's an AOS member near you who's got one and could help out. I'm sure it would be worth hearing.
I'm Richard.
As others have pointed out, there isn't, or shouldn't be a "valve sound". That said, there probably is, and we all know what we mean about it. (Or perhaps that should be a "not horrid solid state sound" - way back when, in the 70's and 80's there were some not very nice sounding SS amps produced and I think that's where this "valve sound" thing kicked off). I asked a designer I know and he put it down to circuit topology. The limitations a valve imposes on the possibilities for design mean that valve amps tend to have a "flavour" of circuit design. But I am certainly in the camp that doesn't think a valve necessarily makes anything better, for all I have heard some valve designs I have liked very much. I have heard some solid state designs I liked even more
Regarding your query - why not ask Alan (Firebottle) if you can try his valve phono stage? I believe he sells it for not much over £200. All he asks is that you pay the postage on to whoever is next on the list to try it. I have tried it into a solid state preamp and it was very nice, and definitely works well without issues. And you can try before you buy. Without having carried out exhaustive market research into every available offering, you could knock me down with a feather if you hear a significantly better valve phono stage for anywhere near the money. Give it a go
Yes, i think it does work in a nutshell. I use an Eastern Electric Minimax into an Exposure pre and power combo and it adds a little body to the sound.
