Page 38 of 40 FirstFirst ... 283637383940 LastLast
Results 371 to 380 of 399
Thread: Magna Audio News & Product Updates
  1. #371
    The horns for the Faital 1" drivers are ready.
    They feature grooves in the mouth and mounting flange for hanging by wire.
    Finished in satin black lacquer.
    These will be part of a multi way system.
  2. #372
    Here is one of the horns with a driver I was sent, mounted up.
    The string is to illustrate the hanging method that will be used.
  3. #373
    Here's a heavy counterweight for an Alphason HR100. 115g.
    Delrin insert and M5 grub screw fitting.
    Highly polished stainless steel.
    Bound for Germany.
  4. #374
    Here's an extra counterweight ring for a Lunstre 801 tonearm, in brass.
    The original weight is 32g.
    Nylon tipped grubscrew.
    Bound for Canada.
  5. #375
    Here's a headshell spacer / weight at 6g.
    Will need used on the Lustre 801 set up, for which I made the extra counterweight.
  6. #376
    Back on Technics SL-1210 armboard work.
    Here's one for a Ortofon TA-110 tonearm. Inc my bespoke 'fit from above' non-invasive fitting kit.
  7. #377
    Here are the installed pics for the extra brass counterweight and heavy headshell spacer for the Lustre 801 tonearm and Kenwood KP-1100 turntable
    Always great to see where things I make end up
  8. #378
    I'm Rob.
    Not looked at your pages before but there is some stunning stuff! So is the stuff on the fosworld link. Even though I am not wearing a hat.....I take it off to you.
    https://youtu.be/ZCBe7-6rw4M
  9. #379
    Here's an armboard for a Walker TT.
    Linn proportions and Linn arm fitting.
    Lacquered birch plywood.
  10. #380
    Quote Originally Posted by Puffin View Post
    Aww thanks Puffin!
