Why Musical Fidelity can slash their prices so low:
Somehow I think not!
Ben Duncan mains conditioner
Samsung QE75Q90T 75" QLED TV
Atacama SE24 stands
If it's based on the A1, then anyone building should invest in big heatsinks. The MF's ran very hot and had a poor reliability record as a result.
"Always carry a large flagon of whisky, in case of snake bite and, furthermore, always carry a small snake."
Kevin
Yeah, somehow I don't think it's quite the same circuit.
Atacama SE24 stands
In my garage I have a spare cylinder head for a 3.2 litre Jaguar straight 6. I think it would make a perfect heatsink for an A1. Might need a 35 horsepower fan as well - just to be on the safe side :-) I have never known an amp run so hot, if satan had an amp it would have to be the A1. It would save him a fortune on his gas bills :-)
They do run exceptionally warm, most people think they're a Class A design you know.
Atacama SE24 stands
Here's a picture of an A1 power section for comparison.
Kevin
Starange u mention him as i bought one of these:
http://cgi.ebay.co.uk/NE5532-HI-FI-S...742.m153.l1262
I think those pots will hit the rubbish bin first of all..
You should never put standard electrolytics so close to such a high intensity heat source. The tantalums are fine but the electrolytics will dry out over a couple of years and might explode. There are electrolytics designed (especially in computer applications) to take this level of heat but they are about four times more expensive.
Curiously because it is a highly biased class AB (like the Krell and some others who call themselves class A) it will run cooler flat out than at half volume or at idle (quiescent). A *real* transistor class A is different and is represented in the UK by Sugden. Of course you get valve class A's like the Puresound A30 and they don't have these problems or design constraints as a valve is basically a voltage amplifiers where as those output trannies in the picture are configurated as current amplifiers and current = heat.
