Checking crossovers doesn't take long and is a good thing to do with any speaker older than 15 years or so old. Capacitors such as Solens or Ansars are relatively cheap and usually can be had in tighter tolrances (certainly to 5%) than many older capacitors, and it makes a heck of a positive difference bringing performance back by re-establishing the correct crossover points. Anything using electrolytics of that age has to be considered as requiring capacitor replacements IME (usually) PLUS some designs can be bettered very easily. For example, the DM2 used a well designed crossover but one which was badly laid out. By that I mean that the air cored inductors were all placed on the same axis, some very close to each other, which is inexcusably poor practice. By simply rotating selected inductors so that axis are all perpendicular can markedly improve performance.
Jerry is a very helpful chap and knows his stuff, but lets not forget that there are a few of us on AoS who are also happy to offer advice freely (Speaker refurbishments are also part of my own business)
