Vertere SG-1 Turntable / Audio Note IO Gold MC
Audio Note AN-S8L MC Transformer
Audio Note Pallas I/C (SUT-Preamp)
Audio Note M6 Phono Preamp
Audio Note CDT 3/Audio Note 4.1X Balanced Signature DAC
Audio Note Kassai Monoblocks
Audio Note Sogon Interconnects
Audio Note Pallas Interconnects
Audio Note AN-Vx Interconnects
Audio Note Sogon Speaker Cables
Audio Note AN-E SPE HE speakers
Audio Note ISIS Power Cables
Loricraft PRC-4 Record Cleaning Machine
hi don..it was an AN dac zero pre production model. it was actually better built than the production models and sounded very nice. i changed may delivery system and this was culled in the process. nice unit though.
As I said I am pretty much finished now I really must syop saying that
going to see a set of nice speakers tomorrow fairly local....yummy!
Are they in Glenrothes?
I'm Shane.
If you like KEF's, Grant...
Perhaps consider the Reference Model One.... http://kef.com/html/gb/explore/about...sOn/index.html
Very nice sounding speakers!
S.
Crackin speakers those Tannoys, wanted a set of the 6 series back in the, I think, late 90's but couldn't afford the big 'uns I wanted.
Sounded really nice.
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
If those 637s are what you're going to look at, you'll be impressed. Just hope they're on the end of a decent system.
Yep, 637's or d70; take your pick. very sought after in the states I believe...here is the specs
Tannoy D70 / 637 Speaker Specifications:
* Design: Design Model Reference 637 - 3-Way Design Employing Dual Concentric Coaxially Mounted Tweeter and Midrange, a Separate Woofer in its Own Chamber, Bi-Wire / Bi-Amp Compatible
* Drivers:
… High frequency: 25mm (1") Tannoy
… Mid frequency: 8” Mid-Woof Tannoy
… Low frequency: 8” Woofer Tannoy
* Frequency response: 40 Hz to 30,000 Hz
* Crossover Frequencies: 1,700 Hz / 400 Hz
* Power handling: 25 – 150W
* Sensitivity: 93 dB (2,83V/1m)
* Nominal Impedance: 6 ohms
* Minimal Impedance: 4 ohms
* Dimensions:
… Height: 32.3” (820 mm)
… Width: 11.3” (286 mm)
… Depth: 10.4” (264 mm)
* Weight: 35.2 lbs ea. ( 16.0 kg.) unpackaged
