its supposed to have a usb key with drivers on it which isnt in box... im trying a workaround.
got a win 7 driver from pathos.. seems to work
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
Some higher rez pics
You need to turn it up quite a bit to get a level of sound from it, which is a surprise, considering the speakers are efficient.
Looks good on the slate.
If its a Windows driver, maybe take a look in the driver settings (if any) for anything obvious?
Is Windows audio disabled?
Is the volume issue there with different software playing music...Jriver, Roon etc?
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
The USB 'key fob' thingy was definitely put in the box. It was in it's own little plastic bag and I might have slipped it in with the instructions.
The volume pot works as a pot should do with full output at approx 100 on the scale, so you have lots of control low down, where most controls nowadays go from nothing to clipping in 1/4 rotation. To get ample volume you will probably have it at 60 but there's plenty more to go.
Yeah volume is at 85/90 and that's not especially loud. Needs to go up to 110 or so to get a bit extra beat. It goes all way to 180.
Just with these speakers being uber efficient it seems a long way to go to get sound.. First 50 does very little tbh.
This is on usb digital from pc and coaxial via digione. Both are approx same level. I've not got an analogue source to try that. It's possible it's louder.
As for the key I will search again for it but I got the download off of pathos, a win 7 one which is the only one really bar an xp.. The rest are for mac.
Nice separation and soundstage.
It takes a bit of warming up tbh but bring hybrid its to be expected and fact its really not been used means it will burn I a fair bit yet. Dac sounds good.. Think its wolfson. Think valves are 88's.
Tis quite heavy and not as big as I thought.
I could remove the table and have it in middle I think.. What ya all think, or keep it up top
My £0.02
Table frames the Oppo nicely and makes for a nice "stack" running up to the TV mounted on the wall?
On the table sitting next to the Oppo would be a bit less busy looking maybe?
Pick yer preferred flavour.
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
Very nice Grant - the proper way to do a hybrid amplifier. 70W/channel ought to be quite sufficient.
https://www.audioaffair.co.uk/pathos...yABEgLQDvD_BwE
That's smart Grant.
Think I'd lose the table & have it in pride of place in the middle.
