Page 330 of 375 FirstFirst ... 230280320328329330331332340 ... LastLast
Results 3,291 to 3,300 of 3741
Thread: I Think I'm sure I'm Finished...or Zeppelin to Sinatra & Back
  1. #3291
    In Malware Bytes,
    Can you add "exceptions" (i.e. allowed apps) to its program list?
    From what you say its definitely a conflict of some kind.
    Unfamiliar with MB, but have used similar programs that let you add these exceptions - basically it sees it as a designated "good" piece of software, and leaves it alone.
    Worth a look?
    yup, it does somewhere lol.. been a while but will give it a go next week.. its played all day, and half of yesterday ok..
    I'm Gary.
    Reckon that would let them play nice together...
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
  3. #3293
    I cant actually find where roon is located as a folder... they seem to have hidden it.
    I'm Gary.
    Can you search for the *.exe file rather than the folder?
    Folder would be where you originally installed it..C:\Program Files (if a y4 bit window s install?)
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
  5. #3295
    I found it with help of a special searchword. It didn't help alas.
    I reported it to roon, but they just say.. It's not roon. Typically I suppose.
    update.. ive disabled web protection in mwb and it is holding up. So something in that and what roon is using kernel wise i think..one causing the other to go too high in memory maybe..
    anyway ive reported this to mwb.. they had issues with this and video games a year or so ago but was supposed to be fixed... maybe the roon high graphics?
    Mwb say they are aware of it and working to fix... Ive done a log report etc via their tool, so should here back soon. I switched the web part on and its been ok today so far so maybe their tool did something... time will tell
    They have now found the issue and are writing a fix which should get applied.
    Dunno how long tho. Cut out today so the Web protection is off again
    Got this cart an age ago and never got round to trying it.. It's marked jvc but I think it's an at10 from audio technika.
    So a bit of quick set up on a nice headshells, also acquired from vinylspinner(nigel). Also an at shell
    Some higher resolution shots of cart etc.
