Page 301 of 375 FirstFirst ... 201251291299300301302303311351 ... LastLast
Results 3,001 to 3,010 of 3741
Thread: I Think I'm sure I'm Finished...or Zeppelin to Sinatra & Back
  1. #3001
    The 3000th post in this gallery thread is mine
    I'm Brian.
    Excellent....Here's 3001
    Regards
    Brian
    Amplifier : Sony TA FB740R
    Speakers : Tannoy 637
  3. #3003
    Thought I, d try these
    A few of you swear by them lol. They are tiny
    I'm Brian.
    Yes , they can make a difference mate . Be careful when soldering them though . If you hold the soldering iron on too long you can damage the units with the heat .
    Regards
    Brian
  5. #3005
    Was hoping i might be able to use push on plugs but not so sure now ive seen them.
    May get sold actually as im not soldering now.
    Fitted some behind unit smart mood lighting today too.
    Ignore diagonal line on speaker, i dropped my stick..doh
    got them to fit them this time. they are a tight fit; virginial even
    That's what I'm looking for. Might take a punt. You can never have enough speaker cables.
  7. #3007
    I'm Brian.
    You might be able to use push connectors if you can find something suitable . If not I'll solder them for you if you send them to me . I'm not sure if I have suitable cable though .
    Regards
    Brian
  8. #3008
    I'm Edward.
    Hi Brian. Hope Grant does not mind me littering his kit thread with a question to you.
    I'm in need of about 24 speaker connectors (don't ask!) which are assured to have a tight lasting fit in the sockets. Not wanting to spend too much but reasonable quality. Happy to solder and heatshrink. Any recommendations?
    cheers
    Edward
  9. #3009
    I'm Brian.
    Hi Edward , depends on how much money you want to spend . The cheaper ones from China are usually OK , however can be variable on occasion .
    Regards
    Brian
  10. #3010
    Mood lighting now its a little darker. Can do most colours but i prefer warm white.
