Page 280 of 375 FirstFirst ... 180230270278279280281282290330 ... LastLast
Results 2,791 to 2,800 of 3741
Thread: I Think I'm sure I'm Finished...or Zeppelin to Sinatra & Back
  1. #2791
    Think it's a keeper
    Result!
  3. #2793
    might be slighly tailend down but its not much. Tony from the mafia will be glad to hear Mr Martyn is sounding better than normal
    Some higher rez pics of cart
    Yo Yo Ma sounds great
    Quoted specification for the SP1 is 2.0 - 4.0g VTF and 25deg VTA. If it were me, I would add 0.5g to your VTF.
    Also, be aware that the effective tip mass for the SP1 is 2.6mg! Anything greater than 1mg will almost certainly damage the inner grooves, so I wouldn't use the cartridge to play your most treasured records.
    its set at 1.95 gm barry. certainly sounds very clear and engaging . output is a little lower, but not much. it has a nos stylus 15 micron in it with little time on it..
    Rpi dug out of its cubby and back running
    Used a battery for power. It's a. Imuto 20,000mAh and very good sonically. 5v of course. I have an adaptor on the power lead going it with a rocker switch so I don't have to disconnect when not in use and there is a USB fly lead there for charging in situ.
    On my phono stage I also use a battery. 12v Anker
    These were used with Beresford stuff often. I got it second hand and it was a great buy making big improvements sonically
    after some checking it seems this is a sp1 version 2. has some modifications done around 1962. has 47k ohm load etc..
    Like your new B&O cartridge, daftee. Like Barry, I've also always rated them. A question for Barry (unless you know): were the cartridges actually made by B&O, or did someone else make them to their spec, such as Ortofon?
    I've always wondered that, as whenever I hear one of those B&Os, it rather reminds me of an SPU!
  10. #2800
    yup, they do. not sure but thought they originally made them themselves, but barry may know better
