If you had put a bid of £100 in, it would automatically just beat the current highest bid by the next biddable amount. E-bay does not do anything on its own. Example: 1st bid £20 but will only show £0.99 until you bid £10, e-bay will outbid you simply because it had the 1st bid of £20. Then you put the £100 bid in. The £20 bid is now beaten and goes to £21 and then every subsequent bid up to your £100 after that you have been out bid until you put in a higher maximum bid. Savey?
TV LG55B7 OLED
