Turntable Advice Wanted.
Hi all,
After tonight playing some 30 year old LPs kindly cleaned by Marco I have re-discovered vinyl. My TT is also 30 years old, but with a new cartridge. It is a Sony PS-LX 100, with very short, as supplied, bog standard, phono interconnects, solder connected inside the case. Inside there appears to be minimum circuitry, transistors or other new fangled electronic bits and pieces.
Question 1) Would it benefit from having some better quality (and longer, for convenience), phono leads soldered in to replace the original leads?
Question 2) If so, does anyone know anyone who could do this for me?
Question 3) Are there any other cost effective mods that could be made to improve the quality of the output.
My aim is to avoid the urge to invest, any time soon, in a new TT.
For further information, just in case it influences any response, the TT connects to the Phono input of my Marantz PM6010OSE KI amp and thence on to MS Mezzo 2 speakers.
All responses, either positive or negative (as long as they are polite ), will be welcome.
DaveK.
My System:
