I have a Toshiba excite pro and I am getting a bushmaster mk1 can I connect to the tablet some how.
Cheers mick
Cheers mick
Mick.
Hi Mick , you need something like these :
http://www.ebay.co.uk/itm/M2Tech-HIF...item3a85dedd79
http://www.ebay.co.uk/itm/Musical-Fi...item3a851024c6
and a coax or optical digital cable .
Thank you,I was hoping I could do it from the head phone out some how
Mick.
Don't think so mate , maybe I'm missing something and some of the computer experts on here can help further . Hope you get it sorted.
Thank u Brian I think your right
Mick.
I'm ChrisB.
He is indeed. The DAC needs a digital signal on the input - the headphone socket will give you an analogue one.
Does it have to be the Bushmaster Mick . These are pretty good for the money and will do the job very well.
http://hifimediy.com/index.php?route...&product_id=87
This should also do the job to get you started .
http://www.ebay.co.uk/itm/FANMUSIC-F...item1e6e9b0c48
Both are USB however.
I'm ChrisB.
If you require a certificate as proof then I'd be glad to provide one!
Might send you a PM later Chris if SWMBO doesn't believe me .
