Hello Chris,
Thanks for the link. My suspicions that you were misunderstanding the German data sheet were based on another Haufe data sheet that I had; I was unable to find the data sheet specific to the T-7883. So here goes:
Übersetzungsverh. : 1:10 (transformer ratio 1:10)
Quellwiderstand : 40 Ω (source impedance 40Ω)
Lastwiderstand : 47 KΩ (load impedance 47KΩ)
Primarpegel : dBu 0.05V
(Primary level 50mV maximum, this is a misprint: ignore the dBu)
Frequenzberich : 20 Hz 20kHz +/- 1dB ref. 1kHz (frequency response)
Klirrfaktor < : 1% (distortion factor)
Impedanz Z : 6,8 kOhm 1 kHz +/-30% an rt-gn Farbe /Pin
(Impedance 68kΩ at 1kHz +/-30% between red –green coloured leads. Must confess I don’t know what Haufe mean by this.)
Vormagnetisierung DC : 0mA
(DC magnetising current 0mA, i.e. don’t allow any DC to flow through the windings.)
Wicklungswiderstand : 11.5 Ohm : 1.3 kOhm +/-10%
(coil/winding impedance (resistance))
Thus the transformer has a turns-ratio of 1:10 and will, when terminated with the 47KΩ input impedance of your preamplifier, present an impedance of 470Ω to your cartridge.
I cannot say what the correct loading impedance for your Linn Trioka should be, since I don’t use one. All I can do is point you to what Linn themselves recommend and to what other Troika users use. The recommended value seems to be 470Ω, so this is where you ought to start. If you find the sound too bright at the top end, then you may need to reduce the value from 470Ω. To do this you will need to connect a shunting resistor across the secondary winding of each transformer. The value of this resistor (in Ohms) can be calculated using the formula:
Shunt resistance = (4700000 x required load impedance)/(47000 – (100 x required load impedance)).
Thus if you want to reduce the load impedance to, say, 200Ω, then you will need to shunt the transformer secondary windings with (4700000 x 200)/(47000 – 20000) = 34815Ω, or 33KΩ. Strictly speaking the impedance of the transformer windings need to be taken into account, but this formula will get you into the ballpark.
So now it’s down to you and your ears to proceed.
Trust this has been of some help.
Regards
