Results 1 to 10 of 15
Thread: The BEAT Turntable at LOTUS !
    I'm richard.
    Default The BEAT Turntable at LOTUS !
    I am extremely excited to announce myself as the UK importer and sole European retailer of Steve Dobbins's incredible Mag-Drive turntable, THE BEAT.
    I will spare you the wordy blurb (links down the bottom if you want to read the full story) but suffice to say that this handbuilt device moves the game on from every other deck I have ever owned by no small margin and on balance of properties it is the equal of the top 2 decks I have ever heard both of which are/were at least 3 times the price. I am absolutely delighted to be representing this amazing deck and it took some persauding to get Steve to commit to a small yearly UK supply. Putting on my enthusiasts hat for a second, I am also totally over the moon having the BEAT as my own personal deck to enjoy as well. Let's just say that I don't think I'll be seeing much daylight over the next few weeks !
    Read the full story and find out exactly what this turntable brings to the party and what makes it so special: http://www.lotus340r.net/items/beat.htm
    Specs and a few quotes down the bottom.
    "I was over Mike's house yesterday to listen to "The Beat". I sat in the sweet-spot for about 2 hours and didn't want to move. This is the best definition I have heard from vinyl in his room. The coherency from top to bottom was remarkable. I feel "The Beat" bested the Rockport in everything but soundstage width. Even though the soundstage was wider, I still felt the images that it created were not as well defined as "The Beat". The engineering felt very mature. Steve has done an amazing job with his new creation. It's something I could definitely live with for the rest of my life. Anyone in the Seattle area has GOT to hear this masterpiece! "
    "What I like about the Beat is it's simpliciy, incredible timing, great, dynamics and black background, The combination with the H5000 DHT, HA3000, Telos and Puritas stands shoulder to shoulder and very often above my reel to reel recorders ( Studer 812, Studer C37, Nagra T)"
    "Yesterday Steve Dobbins drove up from Boise with my new tt, The Beat. Steve mounted a Colobolo arm'ed Reed and my A90 and we listened until midnight. It sounds better than the prototype that i loved in April, and not by a little. Even lower noise floor, and more bass and drive. In 5-6 hours of listening i could not find fault and the music really flowed. It's not right to criticize the Dobbins Technics SP-10 Mk3 'The Beat' replaced, as the Mk3 was really the impetus and departure point for 'The Beat' to begin with. That said, Steve's new tt takes all the great things about the Mk3, and goes to another level (or 2) with everything. There is an ease and refinement to 'The Beat' that makes you relax into the musical flow like the Mk3 never quite could. Fit and finish are top notch everywhere you look."
    "As soon as you settle down to listen you immediately notice how quiet The Beat plays. You hear subtle nuances on recordings that you might not have heard before. Regardless of what LP’s I play or what genre of music that I listen to the results are always the same. The Beat portrays music in an amazingly coherent and elegant fashion. Nothing sounds out of place and there are no ragged edges. The Beat always stays in control."
    "i've heard the Caliburn a few times. While i consider it possibly the most detailed tt i've heard; ultimately I hear what it does not do (as well) compared to the Rockport and the Beat. Music is timing. Period. The best tt's at keeping the time are the ones I enjoy the most. I still enjoy lots of very good belt drive tt's, just not as much."
    "During the Sunday afternoon of Steve Dobbins visit, we were listening to the Who's 'Underture' from Tommy, a 'Simply Vinyl' pressing that is wonderful. Amazing. The bass, and space, and articulation and everything was great. I've played this cut on my other tt's to great enjoyment, but not like this. And then IT happened. One of the bass notes right in the middle of the soundstage literally exploded like a cannot shot. There was a sense of a ring of energy with a hole in the middle. The most physical musical moment of reproduced music i've ever heard. We both were taken aback. What the hell happened ? "
    SPECIFICATIONS:
    £24,995
    Standard Colours, black or white. Custom colours available to order.
    Two armboard plinth as standard. Small single arm or triple arm plinth available to order.
    Dimensions
    (dual arm plinth): 21" x 16" x 7.7" (534 x 410 x 200)
    (smaller one arm plinth available to order)
    Weight
    Platter 11.6kg precisely balanced
    Total Weight 44kg
    Standard platter uses a unique blend of copper, multilayered polymers and aluminium
    White Knight platter uses solid polymer and a gun metal copper alloy platter mat
    Motor:
    Extremely low cogging 3 phase true synchronous with precision transformer based power supply
    Drive torque is adjustable via the power supply to suit individual tastes and environment
    Speeds, 33.33, 45 and 78 rpm
    Bearing:
    Proven 25mm stainless steel shaft riding in an extra long brass housing. Precision machining tolerances better than 5 ten thousand resulting in an extremely quiet and lifetime bearing. Shaft is polished with a 10 micron finish or better and cryo treated to further reduce noise. Custom long life synthetic lubrication is used.
    Support and isolation:
    Stillpoints Ultra 5 as standard under the plinths and power supply. Constrained layer plinth with internal isolation devices for armboards.
    I'm Andy.
    Sweet Jesus that looks nice!
    Me so horny- Impulse H6 Horny
    I am not keen on the styling , Looks feminine sort of makeup compact
    Unable to comment on the sound as I have not listened to it and at £25 K probably never will
    Much prefer the Garrard 301 to the right
    Please note , I cant spell , now you all know
    TAT Sale post Leader " Marcos Mentor "
    Also a pishanto specialist confirmed by Head Daftee
    Real name " Allen " or "Zoomer Nut”, “Numpty Napper”.
    ±± KEEP IT REEL
    I'm Stu.
    Stunning looking bit of kit. Well done and congrats!
    Hifi Pig snoofling out what's hot in hifi.
    I'm Andy.
    No, and we know why
    I'm richard.
    Thanks guys.
    Interestingly, the Garrard is one of Steve's creations as well ... a Dobbins 301 with his custom plinth, platter, bearing etc etc...
    Quite like the Vyger Indian as well if we are talking looks !
    I'm Deleted.
    Listened to the Vyger Atlantis at Whittlebury this year.
    Account Deleted
    Looks like genuine quality to me, Richard. Is it available in black?
    I ask because I agree with Al that the white is rather 'girly'...
    "Count your age by friends, not years. Count your life by smiles, not tears” - John Lennon.
    "When the power of love overcomes the love of power, the world will know peace" - Jimi Hendrix.
    I'm richard.
    Yes, white isn't for everyone
    Most of my demo Allnic pieces are black so it made sense for me. Steve actually used to be a professional car painter many moons ago and does these by hand so can do any colour you like. Might be nice in a really good metallic or fleck paint.
    I'm Deleted.
    Marco, the blurb says black and white are the standard finishes.
    Account Deleted
