It can be lethal stuff that Beryllium,they use it in Microwave oven magnetron's..
I'm Nobody.
Thanks Marco.
Same here, I hate forced secondary filters unless they are designed or properly compatible.
I did actually have a chat with Mark about updating my DAC a few months ago and he suggested these to which I knew nothing about. I didn't know you had one in your dac though so this might be an interesting thing. He suggested to try one on the positive line after the PSU.
Reading up on these on the net, lol.. apparently it can be lethal stuff that Beryllium,they use it in Microwave oven magnetron's. And although I always thought that up until today a Magnetron was something out of Buck Rodgers.. Biddy, Biddy.
Food for thought. Although if the dissection of the one on DIYAudio is true I find it hard to believe that reputable places like Audiocom would sell or even suggest them. I don't know enough about the internals of these to pass any judgement so trying one might be worth a go.
My Dac is a lovely one and love it to bits. So other upgrades come in the form of an external PSU, updated caps and opamps. Any further suggestions would be appreciated.
Tannoyista.com - Audio Equipment Reviews
No worries, Joe. I can only comment on what both Anthony and I clearly heard, after at first being highly dubious that any improvement would have been gained. Anthony, in particular, is usually dead against using these sorts of things, as they tend to act as a 'bandage', not as a genuine 'fix', which at that point also mirrored my own experience.
Therefore, it seems unlikely that we were victims of any (positive) expectation bias
We also continued listening to various different examples of familiar music that evening, and all had clearly benefited from the Bybee upgrade. If you're curious, my advice would be to try just one, wherever Mark considers it being most effective, and see what you think!
I have been using them as OE fitment for around 10 years, and yes I have measured them too, I agree with Simon no appreciable difference in measurement of the component at all.
However the have a well pleasing effect on the overall sound quality.
Best results use on earth's, digital grounds, clock grounds, analogue grounds, digital signal stages, speakers. Also great in PC power supplies too.
You can get carried away with these, however strategically placed they do bring a smile to your face.
As with everything in audio YMMV and I'm sure the anti foo squad will descend on this thread with all guns blazing, I actually use them in my own personal system and have done for a good 10 years.
Coherent Systems
Real high end sound with musicality not hifi
Possibly because you were (quite naturally) only measuring for what you are able to measure, and what you thought needed measuring, using the test equipment currently available for that purpose, rather than perhaps what should've been measured, using the test equipment *actually* required for the job, which is possibly currently unavailable....?
It's this notion that ALL aspects of our understanding of audio are already a 'done deal', based solely on what we currently know and accept, that I find both overly-simplistic and likely the result of (rather misplaced) wishful thinking.
That's why it often pays to have the confidence to say: 'bugger the measurements', and trust yer lugholes instead!!
The original Mk1 Lughole, the best test instrument of all
When I've everything else sorted I'll give one a go.
It will be included within a few other ideas I've got for the DAC so should be good.
Hi Marco,
But how do you make allowance for the placebo effect? Surely there has to be a point where you say that if you really don't believe it should make a difference then any perceived improvement could be placebo? My system sometimes sounds great and sometimes just good, I have no real idea why as there are so many variables involved, and that's without changing any components or tweaking anything.....
Lawrence
Hi Lawrence,
Good question, which is why I highlighted the word "final". This was done deliberately to stress that one's ears are only 'trusted' after all other relevant and available avenues (to you) have been exhausted, in an attempt to 'prove' or 'disprove' the existence of a particular phenomenon.
Of course, in such circumstances, the placebo effect could be very real, but at the end of the day it comes down to how convinced and confident you are, using your own judgement criteria (objective or subjective) as the arbiter, that what you're hearing is real - so whilst placebo effect/expectation bias MUST be always be taken into consideration when assessing these things, and before reaching a final conclusion, it needn't necessarily be the defining factor that explains what you've genuinely experienced
