Originally Posted by
User211
This post makes no sense. Sending someone else won't answer your question as you would need to be here to hear any differences. Someone else can't really do that for you. The two bolded sentences conflict with each other.
A few other points:
The default level 4 valve is an ECC40 which is cheap. It also uses Russian mil spec caps by default which are not expensive. I just decided to buy expensive ones.
The level 3 DAC uses cheap Russian components. According to Lukasz, making a good sounding DAC is hard with cheap components, but a lot easier with expensive ones. I believe I have paid for his experience - read his websites and think about the amount of time he has spent messing with DACs and assessing the results aurally.
Valve prices are usually dictated by fashion or rarity, prices can have no bearing on sound quality. Same can go for caps as well, circuit implementation is the hard part, if its poor then no amount of designer components will make it better.
