Originally Posted by
webby
I'd like to buy some 80s compilation CDs in order to fill in some gaps where I don't have tracks already.
Obviously there will be some crossover (maybe lots) so is there a way that I can compare the track lists of compilations with, not only each other, but also with my iTunes library?
Any of you guys and gals know of a way to do this?
Also, if you know of a good 80s comp, recommend it here
Thanks
Think I'd start with Amazon
You should be able to pick 80s comps up for buttons. Hopefully they will show a track list
Mike
